跳转到主内容
Acer Aspire 5740-5780 LCD Replacement
你所需要的
  1. Acer Aspire 5740-5780 LCD Replacement, Middle Cover: 步骤 1 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement, Middle Cover: 步骤 1 中的图像 2,2
    • Use spudger to gently pry off open middle cover.
    • Then flip the middle cover over onto the keyboard.
  2. Acer Aspire 5740-5780 LCD Replacement: 步骤 2 中的图像 1,1
    • Use tweezers to detach the cable from the volume button board on the middle cover.
  3. Acer Aspire 5740-5780 LCD Replacement: 步骤 3 中的图像 1,1
    • Finally remove the middle cover completely from the computer.
  4. Acer Aspire 5740-5780 LCD Replacement, Keyboard: 步骤 4 中的图像 1,1
    • These latches must be released in order for the keyboard to be removed.
  5. Acer Aspire 5740-5780 LCD Replacement: 步骤 5 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 5 中的图像 2,2
    • Using a spudger, pry the keyboard from the PC, gently.
    • Lift the keyboard and flip it over, so that it rests on its keys.
  6. Acer Aspire 5740-5780 LCD Replacement: 步骤 6 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 6 中的图像 2,2
    • Using your hands, open the latch holding the wire in place, and remove the keyboard.
  7. 注意:步骤 7-10 源自标记为进行中的 指南
    Acer Aspire 5740-5780 LCD Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 步骤 7 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 步骤 7 中的图像 2,2
    • Turn the laptop off and remove the power cord.
  8. Acer Aspire 5740-5780 LCD Replacement: 步骤 8 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 8 中的图像 2,2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  9. Acer Aspire 5740-5780 LCD Replacement: 步骤 9 中的图像 1,1
    • Flip the laptop over on its face, so that the back is showing.
  10. Acer Aspire 5740-5780 LCD Replacement: 步骤 10 中的图像 1,1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  11. Acer Aspire 5740-5780 LCD Replacement, Battery: 步骤 11 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement, Battery: 步骤 11 中的图像 2,2
    • Unlock the battery by flipping a switch near the release latch.
  12. Acer Aspire 5740-5780 LCD Replacement: 步骤 12 中的图像 1,1
    • Slide the release latch to the left to release the battery from the PC.
  13. Acer Aspire 5740-5780 LCD Replacement: 步骤 13 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 13 中的图像 2,2
    • Use your hands to pry the battery free of the computer.
  14. Acer Aspire 5740-5780 LCD Replacement, Back Cover: 步骤 14 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement, Back Cover: 步骤 14 中的图像 2,2
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  15. Acer Aspire 5740-5780 LCD Replacement: 步骤 15 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 15 中的图像 2,2
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
  16. Acer Aspire 5740-5780 LCD Replacement, Hard Drive: 步骤 16 中的图像 1,1
    • Remove the one M2 x L4 screw that secures the hard drive in place.
    • Screw not shown in picture.
  17. Acer Aspire 5740-5780 LCD Replacement: 步骤 17 中的图像 1,1
    • Using an opening tool or your hands, slide the hard drive out of its connector.
  18. Acer Aspire 5740-5780 LCD Replacement: 步骤 18 中的图像 1,1
    • Lift the hard drive out of the computer.
  19. Acer Aspire 5740-5780 LCD Replacement, WLAN Module: 步骤 19 中的图像 1,1
    • Disconnect the black and white antenna cables from the module.
    • Cables not shown.
  20. Acer Aspire 5740-5780 LCD Replacement: 步骤 20 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 20 中的图像 2,2
    • Remove one M2 x L4 screw, which is securing the WLAN Module.
  21. Acer Aspire 5740-5780 LCD Replacement: 步骤 21 中的图像 1,1
    • Carefully remove the module from the system, using plastic opening tools.
  22. Acer Aspire 5740-5780 LCD Replacement, LCD: 步骤 22 中的图像 1,3 Acer Aspire 5740-5780 LCD Replacement, LCD: 步骤 22 中的图像 2,3 Acer Aspire 5740-5780 LCD Replacement, LCD: 步骤 22 中的图像 3,3
    • Retrieve the WLAN antenna wire from underneath the keyboard.
    • Detach the LCD cable from the main board.
  23. Acer Aspire 5740-5780 LCD Replacement: 步骤 23 中的图像 1,2 Acer Aspire 5740-5780 LCD Replacement: 步骤 23 中的图像 2,2
    • Remove 2 M2.5 x L8 screws, using your Philips Head.
  24. Acer Aspire 5740-5780 LCD Replacement: 步骤 24 中的图像 1,1
    • Remove 2 M2.5 x L10 from the front side of the PC.
  25. Acer Aspire 5740-5780 LCD Replacement: 步骤 25 中的图像 1,1
    • Lift the screen away from the Main board of the PC.
结论
Gian Farrell
于03/20/18注册
639 声望
创作了6篇指南
团队
UMass Dartmouth, Team S3-G6, Peak Spring 2018 UMass Dartmouth, Team S3-G6, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G6
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 778
