跳转到主内容
Acer Aspire 5740-5780 Hard Drive Replacement
你所需要的
  1. 注意:步骤 1-4 源自标记为进行中的 指南
    Acer Aspire 5740-5780 Hard Drive Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 步骤 1 中的图像 1,2 Acer Aspire 5740-5780 Hard Drive Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 步骤 1 中的图像 2,2
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Hard Drive Replacement, Battery: 步骤 5 中的图像 1,2 Acer Aspire 5740-5780 Hard Drive Replacement, Battery: 步骤 5 中的图像 2,2
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 7 中的图像 1,2 Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Hard Drive Replacement, Back Cover: 步骤 8 中的图像 1,2 Acer Aspire 5740-5780 Hard Drive Replacement, Back Cover: 步骤 8 中的图像 2,2
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 9 中的图像 1,2 Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
  10. Acer Aspire 5740-5780 Hard Drive Replacement, Hard Drive: 步骤 10 中的图像 1,1
    • Remove the one M2 x L4 screw that secures the hard drive in place.
    • Screw not shown in picture.
  11. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Using an opening tool or your hands, slide the hard drive out of its connector.
  12. Acer Aspire 5740-5780 Hard Drive Replacement: 步骤 12 中的图像 1,1
    • Lift the hard drive out of the computer.
结论
4等其他人完成本指南。
Dwyer Deighan
于03/25/18注册
358 声望
创作了3篇指南
团队
UMass Dartmouth, Team S3-G6, Peak Spring 2018 UMass Dartmouth, Team S3-G6, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G6
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 21
总计 1,342
