跳转到主内容
Acer Aspire 5734z-4836 Screen Replacement
你所需要的
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: 步骤 3 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement: 步骤 3 中的图像 2,2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: 步骤 4 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: 步骤 5 中的图像 1,1
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: 步骤 6 中的图像 1,1
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: 步骤 7 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement: 步骤 7 中的图像 2,2
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: 步骤 8 中的图像 1,1
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: 步骤 9 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement: 步骤 9 中的图像 2,2
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: 步骤 10 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement: 步骤 10 中的图像 2,2
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: 步骤 11 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement: 步骤 11 中的图像 2,2
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: 步骤 12 中的图像 1,3 Acer Aspire 5734z-4836 Screen Replacement: 步骤 12 中的图像 2,3 Acer Aspire 5734z-4836 Screen Replacement: 步骤 12 中的图像 3,3
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: 步骤 13 中的图像 1,2 Acer Aspire 5734z-4836 Screen Replacement: 步骤 13 中的图像 2,2
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
结论
另外一个人完成了本指南。
Susan Cao
于09/12/16注册
121 声望
撰写一个指南
团队
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 840
