跳转到主内容
  1. Acer Aspire 5734z-4836 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 6 中的图像 1,3 Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 6 中的图像 2,3 Acer Aspire 5734z-4836 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
结论
2等其他人完成本指南。
Holly Steininger
于2016年09月12日注册
252 声望
创作了2篇指南
团队
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,248
