当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before removing the battery, power off your laptop and disconnect the AC adapter.
Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
Slide and hold the left latch below the battery.
While holding this latch in place, pry the battery up from its bottom edge.
Lift the old battery out of its compartment.
Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
By using a bit of force some clicks will be heard when removing the cover.
Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
Pull the blue keyboard ribbon cable from the ZIF connector.
When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
Locate the tape on the upper left of the laptop.
Peel off the tape, covering the red-and-black wire connector and the white-and-black speaker wires.
Remove the 5 screws in the middle of the laptop using a #00 Phillips Screwdriver.
In order to access the screw in the upper left corner, you may have to gently move the red and white wires.
Unscrew five screws from the circuit board using a #00 Phillips screwdriver.
Two screws are located below the fan, and three are along the circuit board's right edge.
Take note of the one black screw that goes in the lower-right corner.
The large, silver box next to the circuit board is the optical disk drive, gently slide to the right to remove it.
Do not apply too much pressure on the optical disk drive, as you may risk damaging the disk drive's connector.
Remove the fan from the circuit board.
Due to the accumulated dust inside the fan, you may want to use a small brush to clean off dust.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
