跳转到主内容
Acer Aspire 5536 Display Replacement
你所需要的
  1. Acer Aspire 5536 Display Replacement, Display: 步骤 1 中的图像 1,1
    • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  2. Acer Aspire 5536 Display Replacement: 步骤 2 中的图像 1,2 Acer Aspire 5536 Display Replacement: 步骤 2 中的图像 2,2
    • With a spudger, release the clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom part, specially with the hinges, as there are cables inside.
  3. Acer Aspire 5536 Display Replacement: 步骤 3 中的图像 1,1
    • When all the clips are out, the entire plastic frame should come out easily.
  4. Acer Aspire 5536 Display Replacement: 步骤 4 中的图像 1,2 Acer Aspire 5536 Display Replacement: 步骤 4 中的图像 2,2
    • Carefully disconnect the camera cable.
  5. Acer Aspire 5536 Display Replacement: 步骤 5 中的图像 1,2 Acer Aspire 5536 Display Replacement: 步骤 5 中的图像 2,2
    • Remove the 4 screws located in the sides of the LCD screen.
  6. Acer Aspire 5536 Display Replacement: 步骤 6 中的图像 1,1
    • Remove the other 4 screws that secure the metal LCD frame to the hinges.
  7. Acer Aspire 5536 Display Replacement: 步骤 7 中的图像 1,3 Acer Aspire 5536 Display Replacement: 步骤 7 中的图像 2,3 Acer Aspire 5536 Display Replacement: 步骤 7 中的图像 3,3
    • Take the LCD screen out of the metal frame and flip it towards the keyboard.
  8. Acer Aspire 5536 Display Replacement: 步骤 8 中的图像 1,2 Acer Aspire 5536 Display Replacement: 步骤 8 中的图像 2,2
    • Remove the tape that holds the display cable.
    • Be careful not to take the entire tape away, as this may cause severe damage to the cable.
  9. Acer Aspire 5536 Display Replacement: 步骤 9 中的图像 1,2 Acer Aspire 5536 Display Replacement: 步骤 9 中的图像 2,2
    • Carefully disconnect the cable with a spuger.
  10. Acer Aspire 5536 Display Replacement: 步骤 10 中的图像 1,2 Acer Aspire 5536 Display Replacement: 步骤 10 中的图像 2,2
    • Unstick the cables from the back of the LCD screen.
    • The LCD should be completely free, so just take it out and install a new one.
结论
8等其他人完成本指南。
TechStem
于03/30/10注册
461 声望
撰写一个指南
2条评论
Hi there.. I just bought a display for my aspire 5536 and it seems it has a different fitting for the cable.. in fact I bought an LED display and the original one was an LCD (there is an inverter fitted in the lid under the screen) ok.. my question.. Is that possible under any circumstances to fit this new LED screen in my laptop by changing the video cable with a proper one for this new screen??
Law199 - 回复
Hi, thanks for the info. Can you tell me the part number of the LCD screen? thanks.
Marcelo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 6,882
