跳转到主内容
Acer Aspire 5334-2581 Screen Replacement
你所需要的
  1. Acer Aspire 5334-2581 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Screen Replacement: 步骤 2 中的图像 1,1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Screen Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  6. Acer Aspire 5334-2581 Screen Replacement: 步骤 6 中的图像 1,1
    • With a spudger, release the clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom, there are cable connections, and you don't want to damage them
  7. Acer Aspire 5334-2581 Screen Replacement: 步骤 7 中的图像 1,1
    • With caution disconnect the camera cable.
  8. Acer Aspire 5334-2581 Screen Replacement: 步骤 8 中的图像 1,2 Acer Aspire 5334-2581 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the 4 screws in the side of the LCD. Screen should be able to come of the frame
  9. Acer Aspire 5334-2581 Screen Replacement: 步骤 9 中的图像 1,1
    • Take the screen and flip on top of the keyboard.
    • Unplug the cable connected to the video card.
    • Don't use too much force, you don't want to damage this component.
  10. Acer Aspire 5334-2581 Screen Replacement: 步骤 10 中的图像 1,2 Acer Aspire 5334-2581 Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the tape, and unplug the display cable.
    • Unstick the cable from the back of the LCD, and now the LCD is free to come off. You are ready to install a new one
    • Try not to damage this cable, otherwise replacing it would be so much pain.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 5
总计 364
