跳转到主内容
Acer Aspire 5334-2581 Keyboard Replacement
你所需要的
  1. Acer Aspire 5334-2581 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Keyboard Replacement: 步骤 2 中的图像 1,1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,3 Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,3 Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: 步骤 5 中的图像 3,3
    • The keyboard is held underneath a plastic cover. remove this cover with a spudger.
    • Using a spudger, apply it underneath the keyboard and lift it up.
  6. Acer Aspire 5334-2581 Keyboard Replacement: 步骤 6 中的图像 1,2 Acer Aspire 5334-2581 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Disconnect the keyboard flex cable, and now you are ready to install a new keyboard.
    • Take extra care, and try not to break the the latch that holds the cable in place.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 702
