本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
10等其他人完成本指南。
3条评论
I'm probably going to have to replace my 5253 keyboard, and this guide is head and shoulders above anything else I've seen. However, I'm stuck on step 8.
It says "push the tabs ... in". Is that "in", meaning "away from the keyboard back into the chassis"?
Then, "pull up on the edge of the keyboard". Do I pull up with the tweezers somehow?
On what? The photo on step 8 shows working on the middle tab. Presumably the tabs closer to the left corner have already been pushed in? I'm not getting past that first tab on the top-left.
Any help would be very much appreciated. Thank you.
Tom Asbury - 回复
Gently pull the small white bar that holds the wires in place that hold the keyboard towards you one side at a time so you don’t break the wires accidentally! Be very careful when moving the small white bar so you don’t break the wires that connect to the keyboard! It is not difficult at all! It only takes about 10-12 second to move the small white bar towards you! When you can’t move the small white bar any further towards you then you know it’s safe to remove the keyboard!
Hector E -
