跳转到主内容
Acer Aspire 5253 Back Cover Panel Replacement
你所需要的
  1. Acer Aspire 5253 Back Cover Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over.
  2. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 2 中的图像 1,1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 3 中的图像 1,1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 4 中的图像 1,1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 5 中的图像 1,1
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Back Cover Panel Replacement, Back Cover Panel: 步骤 6 中的图像 1,1
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 7 中的图像 1,1
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 8 中的图像 1,2 Acer Aspire 5253 Back Cover Panel Replacement: 步骤 8 中的图像 2,2
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 Back Cover Panel Replacement: 步骤 9 中的图像 1,1
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
结论
4等其他人完成本指南。
Nathan Hanson
于04/08/14注册
570 声望
创作了2篇指南
团队
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G11
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 2,620
