跳转到主内容
Acer Aspire 5251-1513 Hard Drive Replacement
你所需要的
  1. Acer Aspire 5251-1513 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 4 中的图像 1,2 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 7 中的图像 1,2 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Slide the hard drive to the left until it clicks and then pull it out completely.
  8. Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 8 中的图像 1,3 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 8 中的图像 2,3 Acer Aspire 5251-1513 Hard Drive Replacement: 步骤 8 中的图像 3,3
    • Unscrew the four 3.6 mm screws on either side of the casing with the Phillips #0 screwdriver.
    • Remove the hard drive out of its casing.
    • Be Gentle with the hard rive, only touch the edges.
结论
另外一个人完成了本指南。
Gicely Rodriguez
于02/14/19注册
1,029 声望
创作了5篇指南
团队
USF Tampa, Team S1-G6, Leahy Spring 2019 USF Tampa, Team S1-G6, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 566
