简介
If your Acer Aspire 5100 track pad is not always clicking or not clicking at all, use this guide to replace the track pad.
The trackpad of this device allows the user to move the cursor using their fingers and use the clicking function to select wanted features on the screen. A faulty trackpad can cause the Acer Aspire 5100 to have a jittery cursor, loss of cursor control, or loss of the clicking function on the trackpad.
Before replacing the trackpad, inspect the trackpad connection as well as any debris that might be in the surrounding areas. Occasionally dust can build up and cause connection issues in the track pad.
Once the surrounded areas have been inspected, use this guide to replace the track pad on your Acer Aspire 5100. Be sure the the device is powered down and unplugged from any external power sources.
你所需要的
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
2等其他人完成本指南。
3条评论
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
The Fan must also be removed before removing the touchpad/upper cover.
