简介
If your Acer Aspire screen (model 5100) isn’t producing a clear picture and instead outputs distorted images or intermittent/dead pixels, use this guide to replace the monitor.
The monitor transmits visual data to users through thousands of small pixels. A faulty monitor will transmit distorted or unclear images or no images at all.
Before using this guide, inspect the monitor for any debris that may be interfering with screen quality. Typically, any minute pieces of dust can be removed using an ESD-safe brush or small, damp towel. Be sure to completely shut down your laptop on and off at least two times to confirm that the faulty hardware is the monitor itself.
Before beginning, be sure to turn off your laptop completely and disconnect it from any external power source(s) or monitors if possible.
你所需要的
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Under the panel, remove the two screws that connect the keyboard to the laptop.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
steve foss - 回复
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
8等其他人完成本指南。
