跳转到主内容
Acer Aspire 5100 LCD Monitor Replacement
你所需要的
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: 步骤 1 中的图像 1,2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: 步骤 2 中的图像 1,3 Acer Aspire 5100 LCD Monitor Replacement: 步骤 2 中的图像 2,3 Acer Aspire 5100 LCD Monitor Replacement: 步骤 2 中的图像 3,3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: 步骤 3 中的图像 1,1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: 步骤 4 中的图像 1,1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: 步骤 5 中的图像 1,2 Acer Aspire 5100 LCD Monitor Replacement: 步骤 5 中的图像 2,2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: 步骤 6 中的图像 1,2 Acer Aspire 5100 LCD Monitor Replacement: 步骤 6 中的图像 2,2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: 步骤 7 中的图像 1,1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: 步骤 8 中的图像 1,1
    • Lift up the monitor to detach it.
结论
8等其他人完成本指南。
Brad Rollinson
于09/29/10注册
1,113 声望
创作了7篇指南
团队
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G39
5 名成员
创作了10篇指南
1指南评论
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 31
总计 15,802
