跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Acer Aspire 5100 Keyboard Replacement
你所需要的
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Acer Aspire 5100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Locate the panel above the keyboard that has the power button on it.
    • Remove this panel by using a spudger to pry up the sides.
    • You are using the spudger to release tabs holding the panel in place.
    • After you have used the spudger to release the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: 步骤 2 中的图像 1,3 Acer Aspire 5100 Keyboard Replacement: 步骤 2 中的图像 2,3 Acer Aspire 5100 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Under the panel, locate and remove the two screws that connect the keyboard to the laptop. One screw is located above the F5 button, and the other one is located above the F10 button.
    • Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Release the catch on the ribbon socket, by sliding the two tabs toward the ribbon, then pull the ribbon, which is located under the keyboard, to detach it from the motherboard.
    • Remove the keyboard.
结论
7等其他人完成本指南。
Brad Rollinson
于09/29/10注册
1,113 声望
创作了7篇指南
团队
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G39
5 名成员
创作了10篇指南
一条评论
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 13,268
