跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Install a new keyboard for an Acer 5100 laptop.
  1. Open and push the screen back all the way until it is horizontal with the rest of the laptop. Locate the panel above the keyboard that has the power button on it.
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Locate the panel above the keyboard that has the power button on it.
    • Remove this panel by using a spudger to pry up the sides.
    • You are using the spudger to release tabs holding the panel in place.
    • After you have used the spudger to release the tabs, lift up the panel.
  2. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  3. Under the panel, locate and remove the two screws that connect the keyboard to the laptop. One screw is located above the F5 button, and the other one is located above the F10 button. Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard. Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
    • Under the panel, locate and remove the two screws that connect the keyboard to the laptop. One screw is located above the F5 button, and the other one is located above the F10 button.
    • Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  4. Release the catch on the ribbon socket, by sliding the two tabs toward the ribbon, then pull the ribbon, which is located under the keyboard, to detach it from the motherboard.
    • Release the catch on the ribbon socket, by sliding the two tabs toward the ribbon, then pull the ribbon, which is located under the keyboard, to detach it from the motherboard.
    • Remove the keyboard.
结论
7等其他人完成本指南。
Brad Rollinson
于2010年09月29日注册
1,113 信誉积分
创作了7篇指南
团队
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G39
5 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 12,701
