跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide has been updated! Read the new guide here.
配件
没有特定配件。
  1. Make sure the laptop is turned off and unplugged.
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Locate and remove the 5 screws that secure the panel over the RAM and CPU cover on the upper right hand side. These can be found in the center towards the corner opposite the battery compartment.
    • Locate and remove the 5 screws that secure the panel over the RAM and CPU cover on the upper right hand side. These can be found in the center towards the corner opposite the battery compartment.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Lift up and remove the RAM and CPU cover.
    • Lift up and remove the RAM and CPU cover.
  5. Remove the two Phillips screws securing the fan.
    • Remove the two Phillips screws securing the fan.
    • Carefully disconnect the fan cable from the motherboard.
    • Lift up and remove the fan.
结论
2等其他人完成本指南。
iDeleted
于2010年07月07日注册
2,101 信誉积分
创作了39篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 4,899
