跳转到主内容
Acer Aspire 5 A515-54 Hard Drive Replacement
你所需要的
  1. Acer Aspire 5 A515-54 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn off and unplug your Acer Aspire 5 A515-54.
    • Flip it over so the backside is facing up.
  2. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 2 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 2 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove eleven 9 mm screws securing the back cover.
    • Use a prying tool to gently open the back cover of the laptop.
  3. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 3 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 3 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Be sure to ground yourself or wear an antistatic bracelet to avoid static discharge and damage to the motherboard.
    • Disconnect the battery by gently pulling out the connector.
  4. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 4 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 4 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Notice there is a mounting tray with a cable for the additional HDD. Remove the four 3 mm screws with a Phillips #0 screwdriver.
    • Take out the mounting tray and connector to prepare for the hard drive installation in the next step.
  5. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 5 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 5 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Take the connector from previous step and connect it to the new hard drive.
    • Insert the drive into the mounting tray.
  6. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • There are 2 mm screws that come with the laptop box.
    • Use the Phillips #0 screwdriver to secure the 2 mm screws to the mounting tray, which holds the HDD .
  7. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 7 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 7 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Slide the mounting bracket with the hard drive into the socket (with the cable facing towards the battery).
    • Use the Phillips #0 screwdriver to replace the 3 mm screws and hold the bracket in place.
  8. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 8 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 8 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 8 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the single screw attaching the wireless card to the motherboard.
    • Gently slide the wireless card out of the socket and set it aside in order to connect the hard drive to the motherboard.
  9. Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 9 中的图像 1,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 9 中的图像 2,3 Acer Aspire 5 A515-54 Hard Drive Replacement: 步骤 9 中的图像 3,3
    • Gently insert the hard drive cable into the connector on the motherboard and lock it in place.
    • Slide the wireless card back into the socket and using the Phillips #0 screwdriver, secure with the single screw.
结论
After replace and install the new hard drive to the laptop, you need to format the new drive and that's it. You have upgraded the hard drive of your laptop.
2等其他人完成本指南。
Luan Tu
于09/17/21注册
205 声望
撰写一个指南
团队
York University, Team M-27, Allen Summer 2022 York University, Team M-27, Allen Summer 2022 的会员
YORK-ALLEN-SU22SMG27
1 名成员
创作了1篇指南
一条评论
I currently have a 256gb ssd in my Acer Aspire 5 A515-54. I would like to upgrade to a 1TB ssd and this guide is great but how can I transfer the data to the new ssd?
William Carcoba - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 55
过去 30 天: 214
总计 4,387
