跳转到主内容
Acer Aspire 4810TZ-4120 Keyboard Replacement
你所需要的
  1. Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Locate the five (5) tabs at the top of the keyboard that are holding it in place
    • The 2nd and 3rd pictures are close ups of the tabs
  2. Acer Aspire 4810TZ-4120 Keyboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4810TZ-4120 Keyboard Replacement: 步骤 2 中的图像 2,2
    • The first picture shows the notches in the keyboard that the tabs to into to hold it in place. You cannot see these until the keyboard is removed
    • Insert the flat part of the Spudger tool into one of the holes in front of the tab
    • Push the tab back so it is no longer holding the keyboard.
    • Repeat this step for all of the tabs
  3. Acer Aspire 4810TZ-4120 Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire 4810TZ-4120 Keyboard Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Lay the keyboard upside down
    • Remove any tape that is on the connector with tweezers
    • Gently remove the connector that is on the ribbon cable from the back of the keyboard
    • Your keyboard is now ready to be replaced with a new one
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 520
