跳转到主内容
Acer Aspire 4743-6481 Ram Card Replacement
你所需要的
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: 步骤 2 中的图像 1,1
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: 步骤 3 中的图像 1,1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: 步骤 4 中的图像 1,1
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: 步骤 5 中的图像 1,1
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: 步骤 6 中的图像 1,1
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: 步骤 7 中的图像 1,1
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
结论
AL-Moatasem
于02/22/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017 的会员
USFT-LACY-S17S5G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 710
