跳转到主内容
Acer Aspire 4743-6481 Keyboard Replacement
你所需要的
  1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Keyboard Replacement: 步骤 3 中的图像 1,1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
    • They can be easily identified by looking for the screws with the keyboard icon next to them.
  5. Acer Aspire 4743-6481 Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire 4743-6481 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Turn the laptop over and open it.
    • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
    • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
  6. Acer Aspire 4743-6481 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
    • The connection is located beneath the bottom center of the keyboard.
  7. Acer Aspire 4743-6481 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove piece of tape that covers the connection between the data cable and the connector.
  8. Acer Aspire 4743-6481 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Detach the data cable by flipping up the small black latch on the connector.
    • Once the latch is lifted, the keyboard should be completely free.
结论
3等其他人完成本指南。
David Veres
于02/22/17注册
140 声望
撰写一个指南
团队
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017 的会员
USFT-LACY-S17S5G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 1,375
