跳转到主内容
Acer Aspire 4743-6481 DVD Drive Replacement
你所需要的
  1. Acer Aspire 4743-6481 DVD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 DVD Drive Replacement: 步骤 3 中的图像 1,1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 DVD Drive Replacement, DVD Drive: 步骤 4 中的图像 1,1
    • Remove the 7.0 mm screw, circled in the picture, using a Phillips head screwdriver.
  5. Acer Aspire 4743-6481 DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Once the screw is removed, the DVD drive should easily slide out
  6. Acer Aspire 4743-6481 DVD Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the drive completely.
  7. Acer Aspire 4743-6481 DVD Drive Replacement: 步骤 7 中的图像 1,2 Acer Aspire 4743-6481 DVD Drive Replacement: 步骤 7 中的图像 2,2
    • Face the side of the DVD drive that connects to the laptop and remove the 3mm screw with a Phillips head screwdriver.
    • Put the screw and the bracket to the side as you may need it for your replacement.
结论
另外一个人完成了本指南。
Filippo Santoro
于02/15/17注册
240 声望
创作了2篇指南
团队
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017 的会员
USFT-LACY-S17S5G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 665
