跳转到主内容
Acer Aspire 4741G-332G32Mn Screen Replacement
你所需要的
  1. Acer Aspire 4741G-332G32Mn Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Push the blue opening tool between the edge of the computer and the screen. Slide the tool around the perimeter of the screen.
  2. Acer Aspire 4741G-332G32Mn Screen Replacement: 步骤 2 中的图像 1,1
    • Pop the two circle screw caps off and remove the two screws using a Phillips #0 screwdriver.
    • Remove the computer's frame.
  3. Acer Aspire 4741G-332G32Mn Screen Replacement: 步骤 3 中的图像 1,2 Acer Aspire 4741G-332G32Mn Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the six screws from the four corners of the screen using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the screws from along the sides of the screen (two on each side) using the Phillips #0 screwdriver.
    • Remove the screen adapter from the screen.
    • Remove the screen from the rest of the laptop.
结论
kristen
于03/21/19注册
364 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 727
