跳转到主内容
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
你所需要的
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: 步骤 4 中的图像 1,2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: 步骤 4 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 步骤 7 中的图像 1,1
    • Lift the WiFi card on the left side to remove it.
结论
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,018
