跳转到主内容
Acer Aspire 4520-5464 RAM Replacement
你所需要的
  1. Acer Aspire 4520-5464 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 RAM Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4520-5464 RAM Replacement: 步骤 2 中的图像 2,2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 RAM Replacement: 步骤 3 中的图像 1,1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 RAM Replacement, RAM: 步骤 4 中的图像 1,2 Acer Aspire 4520-5464 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 RAM Replacement: 步骤 5 中的图像 1,3 Acer Aspire 4520-5464 RAM Replacement: 步骤 5 中的图像 2,3 Acer Aspire 4520-5464 RAM Replacement: 步骤 5 中的图像 3,3
    • Push the white tabs located on either side of the top stick of RAM outward.
    • Remove the RAM from the slot on the motherboard.
    • Repeat for the bottom stick of RAM.
结论
另外一个人完成了本指南。
一条评论
interesting good job
Maren Eras - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 1,240
