跳转到主内容
Acer Aspire 4520-5464 Keyboard Replacement
你所需要的
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4520-5464 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire 4520-5464 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: 步骤 6 中的图像 1,2 Acer Aspire 4520-5464 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: 步骤 7 中的图像 1,2 Acer Aspire 4520-5464 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
结论
To reassemble your device, follow these instructions in reverse order using your new keyboard.
另外一个人完成了本指南。
Hunter Gilcrease
于09/21/17注册
367 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 592
