跳转到主内容
Acer Aspire 4520-5464 Hard Drive Replacement
你所需要的
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 5 中的图像 1,3 Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 5 中的图像 2,3 Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the hard drive from the device.
结论
Hunter Gilcrease
于09/21/17注册
367 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 818
