跳转到主内容
Acer Aspire 4520-5464 Graphics Card Replacement
你所需要的
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 2 中的图像 2,2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 3 中的图像 1,1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: 步骤 4 中的图像 1,3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: 步骤 4 中的图像 2,3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: 步骤 4 中的图像 3,3
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 5 中的图像 1,1
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 6 中的图像 1,1
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 7 中的图像 1,2 Acer Aspire 4520-5464 Graphics Card Replacement: 步骤 7 中的图像 2,2
    • Lift up the heat sink line and remove the graphics card.
结论
2等其他人完成本指南。
Hunter Gilcrease
于09/21/17注册
367 声望
创作了3篇指南
团队
一条评论
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 2,347
