跳转到主内容
Acer Aspire 4520-5464 CD/DVD Drive Replacement
你所需要的
  1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 CD/DVD Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: 步骤 2 中的图像 2,2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 CD/DVD Drive Replacement: 步骤 3 中的图像 1,1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: 步骤 4 中的图像 1,3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: 步骤 4 中的图像 2,3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: 步骤 4 中的图像 3,3
    • Remove 7 of the 2mm Phillips #1 screw from the largest panel on back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 CD/DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the .5mm Phillips #1 black screw located on the left side of the panel opening.
  6. Acer Aspire 4520-5464 CD/DVD Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: 步骤 6 中的图像 2,2
    • Using the screwdriver, push the CD drive out of the laptop through the panel exposure.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 14
总计 419
