跳转到主内容
Acer Aspire 3000 RAM Replacement
你所需要的
  1. Acer Aspire 3000 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 RAM Replacement: 步骤 2 中的图像 1,2 Acer Aspire 3000 RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 RAM Replacement: 步骤 3 中的图像 1,2 Acer Aspire 3000 RAM Replacement: 步骤 3 中的图像 2,2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
  5. Acer Aspire 3000 RAM Replacement: 步骤 5 中的图像 1,1
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
  6. Acer Aspire 3000 RAM Replacement: 步骤 6 中的图像 1,1
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
  7. Acer Aspire 3000 RAM Replacement: 步骤 7 中的图像 1,1
    • Lift and pull the cover back towards you to detach it from the device.
  8. Acer Aspire 3000 RAM Replacement: 步骤 8 中的图像 1,1
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
  9. Acer Aspire 3000 RAM Replacement: 步骤 9 中的图像 1,1
    • Pull and lift the chip to release it from the RAM port.
  10. Acer Aspire 3000 RAM Replacement: 步骤 10 中的图像 1,1
    • Repeat step 9 to release the bottom chip from its RAM port.
结论
2等其他人完成本指南。
roro6730
于10/30/16注册
351 声望
创作了2篇指南
团队
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 715
