跳转到主内容
Acer Aspire 3000 Hard Drive Replacement
你所需要的
  1. Acer Aspire 3000 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire 3000 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire 3000 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Unscrew the two 4.6 mm Phillips #1 screws on the left side of the hard drive panel in the lower right corner on the back of the laptop using the phillips head j1 bit.
  5. Acer Aspire 3000 Hard Drive Replacement: 步骤 5 中的图像 1,3 Acer Aspire 3000 Hard Drive Replacement: 步骤 5 中的图像 2,3 Acer Aspire 3000 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool under left side of the hard drive cover and gently pry the cover open.
    • Pull the cover up and out to release the tabs on the right side of the cover and remove from the device.
结论
4等其他人完成本指南。
Courtney Lyons
于10/30/16注册
199 声望
撰写一个指南
团队
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 21
总计 2,101
