跳转到主内容
Acer Aspire 3 A315-21-92FX Speakers Replacement
你所需要的
  1. Acer Aspire 3 A315-21-92FX Speakers Replacement, RAM: 步骤 1 中的图像 1,1
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 2 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 4 中的图像 1,3 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 4 中的图像 2,3 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 4 中的图像 3,3
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 5 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 5 中的图像 2,2
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Speakers Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 7 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 7 中的图像 2,2
  8. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 8 中的图像 1,1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 9 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 9 中的图像 2,2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Speakers Replacement, Battery: 步骤 10 中的图像 1,1
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 11 中的图像 1,3 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 11 中的图像 2,3 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 11 中的图像 3,3
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 12 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 12 中的图像 2,2
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 13 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 13 中的图像 2,2
    • Pull the battery out of the groove.
  14. Acer Aspire 3 A315-21-92FX Speakers Replacement, Speakers: 步骤 14 中的图像 1,1
    • Remove the speaker located in the right hand of the device first using the iFixit Opening Tool.
    • Place the edge of the iFixit Opening Tool under the speaker and pull it upward.
  15. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 15 中的图像 1,1
    • Remove the speaker from the left side of the computer using the iFixit Opening Tool.
  16. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 16 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 16 中的图像 2,2
    • The cable that is connecting the speakers to the motherboard is placed under these plastic cables that are glued to the computer.
    • Remove these glued cables using the iFixit Opening Tool.
  17. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 17 中的图像 1,3 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 17 中的图像 2,3 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 17 中的图像 3,3
    • Detach the speaker connector from the motherboard with your fingers or the iFixit Opening Tool.
  18. Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 18 中的图像 1,2 Acer Aspire 3 A315-21-92FX Speakers Replacement: 步骤 18 中的图像 2,2
    • Remove the speakers with your hands.
结论
3等其他人完成本指南。
gghhh
于01/14/20注册
329 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 1,422
