跳转到主内容
Acer Aspire 3 A315-21-92FX Hard Drive Replacement
你所需要的
  1. Acer Aspire 3 A315-21-92FX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  4. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 步骤 4 中的图像 1,2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
结论
4等其他人完成本指南。
ShengKun Lu
于01/14/20注册
705 声望
创作了3篇指南
团队
2条评论
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
Zeek tuyishime - 回复
These connecting cable is missing, where to buy these cable. Pls tell the cable name
jayesh v v - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 97
总计 6,027
