跳转到主内容
Acer Aspire 3 A315-21-92FX Battery Replacement
你所需要的
  1. Acer Aspire 3 A315-21-92FX Battery Replacement, RAM: 步骤 1 中的图像 1,1
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 2 中的图像 1,2 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 4 中的图像 1,3 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 4 中的图像 2,3 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 4 中的图像 3,3
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 5 中的图像 1,2 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 5 中的图像 2,2
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Battery Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 7 中的图像 1,2 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 7 中的图像 2,2
  8. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 8 中的图像 1,1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 9 中的图像 1,2 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 9 中的图像 2,2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Battery Replacement, Battery: 步骤 10 中的图像 1,1
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 11 中的图像 1,3 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 11 中的图像 2,3 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 11 中的图像 3,3
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 12 中的图像 1,2 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 12 中的图像 2,2
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 13 中的图像 1,2 Acer Aspire 3 A315-21-92FX Battery Replacement: 步骤 13 中的图像 2,2
    • Pull the battery out of the groove.
结论
6等其他人完成本指南。
ShengKun Lu
于01/14/20注册
705 声望
创作了3篇指南
团队
一条评论
Thanks for this tutorial ! You just forgot 3 screws: 2 on the right of the hard drive, and 1 on the top left =)
Troublicious - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 36
过去 30 天: 227
总计 11,099
