跳转到主内容
Acer Aspire E5-574-53QS Back Panel Removal
你所需要的
  1. Acer Aspire  E5-574-53QS Back Panel Removal, Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 1 中的图像 1,1
    • Turn the laptop so that the back panel faces up.
    • Remove eighteen screws from the back cover using a Phillips #0 screwdriver.
  2. Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 2 中的图像 1,3 Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 2 中的图像 2,3 Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to ease out the optical drive from the side of the laptop, then pull it the rest of the way out.
    • Remove the three screws along the edge of the optical drive port with a Phillips #0 screwdriver.
  3. Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 3 中的图像 1,2 Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 3 中的图像 2,2
    • Stick an opening tool into the seam of the laptop case and begin prying the back panel from the device to loosen it. Slowly move all the way around the laptop, prying periodically to release each of the clips.
    • Do not completely remove it. Only loosen the connection between the back panel and the laptop. Be careful not to damage the VGA port, as that can easily get caught on the back panel during this step.
    • Lift the back panel up to reveal the cable connecting the back case to the motherboard.
  4. Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 4 中的图像 1,3 Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 4 中的图像 2,3 Acer Aspire  E5-574-53QS Back Panel Removal: 步骤 4 中的图像 3,3
    • Carefully remove the cable from the socket.
    • The socket is very sensitive, so be gentle when pushing the cable connector out.
    • Fully remove the back case from the device.
结论
2等其他人完成本指南。
Rolf Konrad
于02/26/20注册
159 声望
撰写一个指南
一条评论
I need to know what kind of screews go on that laptop because i bought one like this without screews. Model in question is E5 722G-302Y but i think they are similar enough .
Vladimir Hromis - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 68
总计 3,360
