跳转到主内容
加入维修社区 - 创建账户
Acer AL1916 Stand Replacement
你所需要的
  1. Acer AL1916 Stand Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Stand Replacement: 步骤 2 中的图像 1,2 Acer AL1916 Stand Replacement: 步骤 2 中的图像 2,2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Stand Replacement: 步骤 3 中的图像 1,2 Acer AL1916 Stand Replacement: 步骤 3 中的图像 2,2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
结论
8等其他人完成本指南。
Keith
于10/06/11注册
375 声望
创作了4篇指南
团队
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G26
4 名成员
创作了14篇指南
2指南评论
Worked great…never would have guessed how to do it. Thanks.
GREG HILL - 回复
I would never have worked out how to remove the stand without this - thank you.
Mark Philipson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 47
总计 20,916
