跳转到主内容
Acer AL1916 Outer Case Replacement
你所需要的
  1. Acer AL1916 Outer Case Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Outer Case Replacement: 步骤 2 中的图像 1,2 Acer AL1916 Outer Case Replacement: 步骤 2 中的图像 2,2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Outer Case Replacement: 步骤 3 中的图像 1,2 Acer AL1916 Outer Case Replacement: 步骤 3 中的图像 2,2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Outer Case Replacement, Outer Case: 步骤 4 中的图像 1,2 Acer AL1916 Outer Case Replacement, Outer Case: 步骤 4 中的图像 2,2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Outer Case Replacement: 步骤 5 中的图像 1,3 Acer AL1916 Outer Case Replacement: 步骤 5 中的图像 2,3 Acer AL1916 Outer Case Replacement: 步骤 5 中的图像 3,3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Outer Case Replacement: 步骤 6 中的图像 1,2 Acer AL1916 Outer Case Replacement: 步骤 6 中的图像 2,2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
结论
Keith
于10/06/11注册
351 声望
创作了4篇指南
团队
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G26
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 1,255
