跳转到主内容
Acer AL1714 Power Supply Board
你所需要的
  1. Acer AL1714 Power Supply Board, Power Supply Board: 步骤 1 中的图像 1,2 Acer AL1714 Power Supply Board, Power Supply Board: 步骤 1 中的图像 2,2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Supply Board: 步骤 2 中的图像 1,3 Acer AL1714 Power Supply Board: 步骤 2 中的图像 2,3 Acer AL1714 Power Supply Board: 步骤 2 中的图像 3,3
    • Take the edge tool or a metal ruler and insert it into bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Supply Board: 步骤 3 中的图像 1,3 Acer AL1714 Power Supply Board: 步骤 3 中的图像 2,3 Acer AL1714 Power Supply Board: 步骤 3 中的图像 3,3
    • Remove the Flat Flex Cable from the Power Supply board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Supply Board: 步骤 4 中的图像 1,3 Acer AL1714 Power Supply Board: 步骤 4 中的图像 2,3 Acer AL1714 Power Supply Board: 步骤 4 中的图像 3,3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 Power Supply Board: 步骤 5 中的图像 1,2 Acer AL1714 Power Supply Board: 步骤 5 中的图像 2,2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flat Power Cable cover in place.
    • Lift up and remove the Flat Power Cable cover.
    • (Careful: it may be sharp)
  6. Acer AL1714 Power Supply Board: 步骤 6 中的图像 1,1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 Power Supply Board: 步骤 7 中的图像 1,2 Acer AL1714 Power Supply Board: 步骤 7 中的图像 2,2
    • Lift up on the back of the metal cage slightly.
    • Pull the cage toward self.
    • (Must be careful to free the cover of the VGA port and power supply input)
  8. Acer AL1714 Power Supply Board: 步骤 8 中的图像 1,3 Acer AL1714 Power Supply Board: 步骤 8 中的图像 2,3 Acer AL1714 Power Supply Board: 步骤 8 中的图像 3,3
    • Lift up on the Flat Flex Cable holder tabs to release the cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 Power Supply Board: 步骤 9 中的图像 1,3 Acer AL1714 Power Supply Board: 步骤 9 中的图像 2,3 Acer AL1714 Power Supply Board: 步骤 9 中的图像 3,3
    • Unplug the 4 backlight wires from their ports on the Power Supply Board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling and pulling the wires out of place)
  10. Acer AL1714 Power Supply Board: 步骤 10 中的图像 1,1
    • Unscrew the 5 screws holding the joined Power Supply and Video Display boards on.
  11. Acer AL1714 Power Supply Board: 步骤 11 中的图像 1,2 Acer AL1714 Power Supply Board: 步骤 11 中的图像 2,2
    • Lift and remove the joined Power Supply and Video Display boards.
  12. Acer AL1714 Power Supply Board: 步骤 12 中的图像 1,3 Acer AL1714 Power Supply Board: 步骤 12 中的图像 2,3 Acer AL1714 Power Supply Board: 步骤 12 中的图像 3,3
    • Carefully detach the Power Supply and Video Display boards at their connector joint.
    • Replace the Power Supply Board with a new part.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 的会员
USFT-BROWN-F14S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,238
