跳转到主内容
Accessing Samsung ML2510 Circuit Board
你所需要的
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 1,3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 2,3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 3,3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: 步骤 3 中的图像 1,3 Accessing Samsung ML2510 Circuit Board: 步骤 3 中的图像 2,3 Accessing Samsung ML2510 Circuit Board: 步骤 3 中的图像 3,3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: 步骤 4 中的图像 1,3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: 步骤 4 中的图像 2,3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: 步骤 4 中的图像 3,3
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: 步骤 5 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: 步骤 6 中的图像 1,3 Accessing Samsung ML2510 Circuit Board: 步骤 6 中的图像 2,3 Accessing Samsung ML2510 Circuit Board: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: 步骤 7 中的图像 1,3 Accessing Samsung ML2510 Circuit Board: 步骤 7 中的图像 2,3 Accessing Samsung ML2510 Circuit Board: 步骤 7 中的图像 3,3
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: 步骤 8 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: 步骤 9 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: 步骤 10 中的图像 1,2 Accessing Samsung ML2510 Circuit Board: 步骤 10 中的图像 2,2
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
结论
3等其他人完成本指南。
bbaustin
于10/12/11注册
268 声望
创作了6篇指南
团队
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G18
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,829
