当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Make sure your phone is turned off.
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Retrieve your SIM card.
Separate the front cover from the base of the phone.
Set the front cover, as indicated, aside.
Remove the screws indicated using a T6 Torx screwdriver.
Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
Separate the screen assembly from the base of the phone.
Set the screen assembly, as indicated, aside.
The vibrating unit can now be accessed. Note its location in the phone.
The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
The vibrating unit is now removed.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与2其他贡献者
于04/09/10注册
130 声望
创作了8篇指南
徽章: 8
+ 5更多徽章
CPSU-JOHANN-S10S29G64
3 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 10
总计 1,614
