跳转到主内容
Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013
你所需要的
  1. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013, Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 1 中的图像 1,1
    • There are two tabs on both sides of where the cable enters the back of the keyboard. Use the metal spudgers to gently pull up the tabs. These are circled in red on the picture.
  2. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 2 中的图像 1,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 2 中的图像 2,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to remove the rubber pads at each corner.
    • Once removed, there are 10mm screws below each pad. Remove the screws using the phillips-head screwdriver.
  3. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 3 中的图像 1,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 3 中的图像 2,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 3 中的图像 3,3
    • Utilizing your broad metal spudger, begin to pry off the faceplate of the keyboard.
    • There are small tabs between the faceplate and the keyboard's base that must be released. There are four tabs along the front of the keyboard and two along each side. Examples of the tabs you are looking for are circled in the third image.
  4. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 4 中的图像 1,1
    • Find where the cable enters the back of the keyboard. There are two screws on either side of the tab holding the cable in. Once removed, the tab should slide out of the keyboard.
  5. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 5 中的图像 1,1
    • Lift the covering of the LED logo vertically out of the slot.
  6. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 6 中的图像 1,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 6 中的图像 2,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 6 中的图像 3,3
    • Remove the remaining eight 10 mm screws using the Phillips Head screwdriver.
    • To remove the board from the case pull the board up and away from the audio jack holes to allow the audio jacks to slide out of their holes in the side of the backing.
  7. Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 7 中的图像 1,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 7 中的图像 2,3 Accessing LEDs and Switches in Razer Blackwidow Ultimate 2013: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Keys can be removed from the board by pulling them upward with your fingers.
    • Larger keys can be removed by lifting the key away to expose the metal pin underneath for added support. Detach the pin by pulling out from the plastic tabs holding the pin using tweezers.
结论
To reassemble your keyboard, follow these instructions in reverse order. There are no special steps to put this back together and it is just as easy to put it back together.
13等其他人完成本指南。
Jacob Scoles
于09/17/15注册
549 声望
创作了2篇指南
团队
IUPUI, Team 2-3, Harley Fall 2015 IUPUI, Team 2-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S2G3
4 名成员
创作了4篇指南
6条评论
Can I use this guide for my Razer Blackwidow Ultimate 2014 Tournament edition?
Boogeyman - - 回复
Yeah it’s pretty much the same procedure. I don’t know about the 2013, but the 2014 faceplate has two points on each of the sides where you have to get the spudger in and pry outwards a bit to release two tabs. They’re pretty stiff.
Randy - 回复
Yeah, it’s pretty much the same procedure. I don’t know about this model, but the 2014 has two spots on each side where you have to pry out with the spudger to release some pretty stiff tabs.
Randy - 回复
Thank you so much, this guide was great in helping me fix my keyboard. I really appreciate it
B P - 回复
how to put key-macro into the Razer flash–memory?
ein Stein - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 86
总计 32,550
