跳转到主内容
加入维修社区 - 创建账户
Accessing Apple Cinema Display M8149 Control Boards
你所需要的
  1. Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 步骤 1 中的图像 1,3 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 步骤 1 中的图像 2,3 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 步骤 1 中的图像 3,3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Accessing Apple Cinema Display M8149 Control Boards: 步骤 2 中的图像 1,3 Accessing Apple Cinema Display M8149 Control Boards: 步骤 2 中的图像 2,3 Accessing Apple Cinema Display M8149 Control Boards: 步骤 2 中的图像 3,3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
  3. Accessing Apple Cinema Display M8149 Control Boards: 步骤 3 中的图像 1,2 Accessing Apple Cinema Display M8149 Control Boards: 步骤 3 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
  4. Accessing Apple Cinema Display M8149 Control Boards: 步骤 4 中的图像 1,3 Accessing Apple Cinema Display M8149 Control Boards: 步骤 4 中的图像 2,3 Accessing Apple Cinema Display M8149 Control Boards: 步骤 4 中的图像 3,3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Accessing Apple Cinema Display M8149 Control Boards: 步骤 5 中的图像 1,2 Accessing Apple Cinema Display M8149 Control Boards: 步骤 5 中的图像 2,2
    • Gently lift the large metal cover which spans across the back of the whole display.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G41
5 名成员
创作了18篇指南
1指南评论
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 72
总计 6,246
