跳转到主内容
Access to RAM and CPU from why! W253EU
你所需要的
  1. Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 1,3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 2,3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 3,3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: 步骤 2 中的图像 1,2 Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: 步骤 2 中的图像 2,2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Access to RAM and CPU from why! W253EU: 步骤 3 中的图像 1,3 Access to RAM and CPU from why! W253EU: 步骤 3 中的图像 2,3 Access to RAM and CPU from why! W253EU: 步骤 3 中的图像 3,3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Access to RAM and CPU from why! W253EU: 步骤 4 中的图像 1,1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
结论
For reassembly, follow the instructions in reverse order.
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
30,884 声望
创作了264篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 257
