跳转到主内容
Abask A8 Internal Assembly Replacement
你所需要的
  1. Abask A8 Internal Assembly Replacement, Internal Assembly: 步骤 1 中的图像 1,3 Abask A8 Internal Assembly Replacement, Internal Assembly: 步骤 1 中的图像 2,3 Abask A8 Internal Assembly Replacement, Internal Assembly: 步骤 1 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws on the front plate.
    • Gently insert a pry between the front panel and the main body, working around the edges to pop it off.
    • Pull the main body from the shell.
    • Be careful not to damage the ribbon cable, as they are very fragile. Ribbon cables look like thin pieces of silver duct-tape.
  2. Abask A8 Internal Assembly Replacement: 步骤 2 中的图像 1,2 Abask A8 Internal Assembly Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the screen.
  3. Abask A8 Internal Assembly Replacement: 步骤 3 中的图像 1,3 Abask A8 Internal Assembly Replacement: 步骤 3 中的图像 2,3 Abask A8 Internal Assembly Replacement: 步骤 3 中的图像 3,3
    • Remove the internal facing camera with care not to strain the connected ribbon cable.
    • Lift up the black ZIF locking flap and disconnect the ribbon cable.
  4. Abask A8 Internal Assembly Replacement: 步骤 4 中的图像 1,3 Abask A8 Internal Assembly Replacement: 步骤 4 中的图像 2,3 Abask A8 Internal Assembly Replacement: 步骤 4 中的图像 3,3
    • Lift the camera connector ZIF locking flap.
    • Gently remove the ribbon cable from the connector and fully remove the camera.
  5. Abask A8 Internal Assembly Replacement: 步骤 5 中的图像 1,2 Abask A8 Internal Assembly Replacement: 步骤 5 中的图像 2,2
    • Using a Jimmy prying tool, lift the supercapacitor out of its slot.
    • Be careful not to puncture the supercapacitor.
结论
Logan B
于03/18/25注册
171 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-4, Konn Spring 2025 UMass Dartmouth, Team 4-4, Konn Spring 2025 的会员
UMASSD-KONN-S25S4G4
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 77
