跳转到主内容
Aarp RealPad MA7BX2 Speakers Replacement
你所需要的
  1. Aarp RealPad MA7BX2 Speakers Replacement, Speakers: 步骤 1 中的图像 1,1
    • Loosen the back cover using the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. Aarp RealPad MA7BX2 Speakers Replacement: 步骤 2 中的图像 1,1
    • Gently place the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the plastic opening tool.
  3. Aarp RealPad MA7BX2 Speakers Replacement: 步骤 3 中的图像 1,1
    • Gently pull off the black tape.
  4. Aarp RealPad MA7BX2 Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove the wires with the tweezers by pulling them upward.
  5. Aarp RealPad MA7BX2 Speakers Replacement: 步骤 5 中的图像 1,2 Aarp RealPad MA7BX2 Speakers Replacement: 步骤 5 中的图像 2,2
    • Pull the speakers upward with you hand.
结论
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 176
