跳转到主内容
  1. Disassembly of AYA TV. I believe my model is close to a 22" 56cm  AYA TV A22FHD2203. It's a small TV.
    • Disassembly of AYA TV. I believe my model is close to a 22" 56cm AYA TV A22FHD2203. It's a small TV.
    • Remove the stand, remove the screws and remove the back cover by running a piece of plastic around the edges. Unscrew the board Vestel 17IPS61-3. Gently detach it from the green board.
    • Test the diodes marked with a D and a number, side by side on the board (just above the yellow transformer). In my case the ones marked D9, D25 and D10 allowed a current to flow in the reverse direction.
    • How to test a diode: https://www.fluke.com/en-gb/learn/best-p...
    • Unsolder the diodes and test them again. In fact only one now showed up as defective. (The others appeared defective because of a path for the current through the circuit board.)
    • Purchase replacement diodes. I was able to find 10 SR5100 diodes on Amaqzon for less than 1€ (Aug 2018).
    • Resolder the diodes, standing proud from the board like the old ones, and making sure they're the right way round. Clip the leads on the other side of the board with a pair of wire cutters. Reassemble the TV. Problem solved - the TV works again.
  2. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
结论
To reassemble your device, follow the instructions in reverse.
特别感谢这些译者︰
100%
Philip Le Riche正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Pierre
于2018年10月25日注册
55 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 23
总计 250
