跳转到主内容
ATT Trimline 210M Speaker Replacement
你所需要的
  1. ATT Trimline 210M Speaker Replacement, ATT Trimline 210M Back Cover Disassembly: 步骤 1 中的图像 1,1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Speaker Replacement: 步骤 2 中的图像 1,1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Speaker Replacement: 步骤 3 中的图像 1,1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Speaker Replacement: 步骤 4 中的图像 1,1
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Speaker Replacement, ATT Trimline 210M Motherboard Disassembly: 步骤 5 中的图像 1,1
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Speaker Replacement: 步骤 6 中的图像 1,1
    • Carefully move the motherboard up to remove it.
  7. ATT Trimline 210M Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Carefully detach the black and red wires
  8. ATT Trimline 210M Speaker Replacement: 步骤 8 中的图像 1,1
    • Use the iFixit iOpener to warm the adhesive from the front of the phone, in order to remove the speaker from the face plate safely.
  9. ATT Trimline 210M Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove speaker
结论
另外一个人完成了本指南。
Corey
于02/10/16注册
343 声望
创作了3篇指南
团队
USF Tampa, Team 4-2, Lacy Spring 2016 USF Tampa, Team 4-2, Lacy Spring 2016 的会员
USFT-LACY-S16S4G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 316
