跳转到主内容
ATT Trimline 210M Back Cover Disassembly
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. ATT Trimline 210M Back Cover Disassembly, ATT Trimline 210M Back Cover Disassembly: 步骤 1 中的图像 1,1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Back Cover Disassembly: 步骤 2 中的图像 1,1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Back Cover Disassembly: 步骤 3 中的图像 1,1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Back Cover Disassembly: 步骤 4 中的图像 1,1
    • You will have the motherboard and speaker exposed to you.
结论
Juan Carrillo
于02/10/16注册
406 声望
创作了3篇指南
团队
USF Tampa, Team 4-2, Lacy Spring 2016 USF Tampa, Team 4-2, Lacy Spring 2016 的会员
USFT-LACY-S16S4G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 18
