当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
Unplug the battery by squeezing your hands on the small white plug and lifting it up.
Do not pull on the wire itself because you might damage the wire!
The battery is now detached and ready to be removed by lifting it out.
Remove the two 3.75 mm screws with a PH1 screwdriver.
Use a plastic opening tool to remove the handset case.
Be careful to not lift the case too far as the ringer cable is attached to the case.
Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
Use an anti-static wrist strap to prevent damage to the motherboard.
The keypad lies on the top of the motherboard and is easily detachable.
Remove the keypad.
Replace the plastic display screen, or the keypad buttons as needed.
取消:我没有完成这个指南。
与3其他贡献者
于08/27/15注册
313 声望
创作了3篇指南
徽章: 6
+ 3更多徽章
USFT-SULLIVAN-S16S1G1
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 7
总计 499
