跳转到主内容
ATT EL52300 Keypad/Plastic Display Screen Replacement
你所需要的
  1. ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: 步骤 1 中的图像 1,2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Keypad/Plastic Display Screen Replacement: 步骤 2 中的图像 1,1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: 步骤 3 中的图像 1,2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 Keypad/Plastic Display Screen Replacement: 步骤 4 中的图像 1,2 ATT EL52300 Keypad/Plastic Display Screen Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 Keypad/Plastic Display Screen Replacement: 步骤 5 中的图像 1,2 ATT EL52300 Keypad/Plastic Display Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: 步骤 6 中的图像 1,2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: 步骤 6 中的图像 2,2
    • The keypad lies on the top of the motherboard and is easily detachable.
    • Remove the keypad.
  7. ATT EL52300 Keypad/Plastic Display Screen Replacement: 步骤 7 中的图像 1,1
    • Replace the plastic display screen, or the keypad buttons as needed.
结论
Katty
于08/27/15注册
313 声望
创作了3篇指南
团队
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 493
